Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
deckover low profile trailers
D beatty
05-29-2012 22:50:23
I'am looking to buy a 14,000lb. bumper pull low profile deckover with 20ft.deck and a 3 ft. beaver tail.I have kind of narrowed it down to Liberty Trailer, PJ trailer or a Johnson Trailer( known as Roadwarrior). These trailers are built alike and in about the same price range. I'am looking for input from owners of these trailers good or bad. Thanks
BarryfromIA
06-10-2012 19:30:47
 Re: deckover low profile trailers in reply to D beatty, 05-29-2012 22:50:23
I have a 20ft PJ B5 10000#. I pull it with a 3/4 ton Dodge and like it. Mine has 2ft dove tail and I can load a tractor off a good size hump in the yard with no ramps. The B5 and B6 trailers have drive over fenders.
d beatty
06-10-2012 21:35:21
 Re: deckover low profile trailers in reply to BarryfromIA, 06-10-2012 19:30:47
Barry I am looking at the B8 trailer in the PJ line. Looks like a well built trailer from photos but haven't seen one personly. No dealers close by ( nearest delear is about 90 miles away and only sells no trailers in stock) . I have seen a Liberty trailer and it looks a lot like thr pj trailer.
George Marsh
06-18-2012 05:05:57
 Re: deckover low profile trailers in reply to d beatty, 06-10-2012 21:35:21
I know a guy who bought a Liberty dump trailer and wasn't happy with it..Liberty wanted him to bring it back to fix a weld...not a happy man...
d beatty
06-18-2012 07:35:14
 Re: deckover low profile trailers in reply to George Marsh, 06-18-2012 05:05:57
George I have a PJ dealer that is tring to get me a Model F8, 24 foot, 14,000 lb. low profile trailer with 3 fold up ramps. Thanks for your imput I have had several other people tell me of problems with Liberty.Everybody I talk to about PJ trailers give it a thumbs up. But every company has problems from time to time.
1 Dollar
06-08-2012 13:43:01
Here's a 32+4 low profile gooseneck. On a deckover low pro I would want no less than a 4 foot dove.
44 massey
06-07-2012 14:57:08
I have an 18ft 7000lb PJ and really like it. Pulls very nice loaded and empty tho wish it was a 14000. It seems well built.
Meangreen
06-07-2012 08:57:22
Take a look at this guy. Might find something that works better.
http://sltrailers.com/
mkirsch
06-05-2012 08:07:48
With a fifth wheel, all that "tippy motion" turns into frame twist.
George Marsh
06-02-2012 07:10:50
I would avoid buying any trailer with a ramp that looks like this one. They tend to kick up when you put a load on them. The knee support should be in front of the pivot not behind. I had to modify mine. Just my $.02.
cd1
06-01-2012 06:20:18
check out the PJ Buggy Hauler. It is not 14K but it is a about as low as you can get and still have full 102" wide and 20' long. I have one, I like it for most things.
bobs old iron
05-31-2012 12:08:23
i have a MAY CO trailer that has run-over wheel-wells, can hold 3k, not a real low profile, has 3 ft dove, but have ramps to make up the 6ft needed for loading, only because of low deck..
FC Andy
05-31-2012 15:43:41
 Re: deckover low profile trailers in reply to bobs old iron, 05-31-2012 12:08:23
Question: How well does that adapter from gooseneck to fifth- wheel work? Does that eliminate some of the tippy- motion of the trailer when you hit a bump?
bobs old iron
06-02-2012 11:41:34
 Re: deckover low profile trailers in reply to FC Andy, 05-31-2012 15:43:41
FC ANDY:::most of the goose neck trailers that have the round tube connectors, that hold the coupler in, can be removed and insert the fifth wheel pin tube in,,i hook it up to my 5th wheel set-up and it pulls and ride o-k...
d beatty
05-30-2012 17:06:16
On the low profile Liberty and PJ trailers the 3 foot beaver is standard equipment. The Johnson trailer uses a 4 foot but trailer set a little bit higher than the other two.I have seen a Liberty low profile setting next to a standard height trailer and if you put the ramps down on both off them there is very little differance in the pitch of climb to get on trailer. I'm going with bumper because it would be easier to move around the place if the truck is not available. Also if I would break down on the road all my freind are running bumper pull so I would have no trouble getting somebody to get trailer home.
Ralph Bauer
05-30-2012 12:46:11
even on a low profile, 3 ft dove/beaver is too short, 4ft+ at a minimum, 5' is better.
Just curious, but wouldn't it be better (for your circumstances) to look at a gooseneck trailer?
Mike M
05-30-2012 05:19:24
That 3 ft. tail sounds kinda short ? ours had a 5 ft. you don't want them any steeper then needed.
Butch -Ia
05-30-2012 05:03:01
I had a PJ 20ft bumper pull before I got my gooseneck and it was a good trailer and pulled easy, Just not big enough. If you need it get the third ramp if you can.
Copyright © 1997-2015 Yesterday's Tractor Co.
