I 100% agree that's more important than where you buy them. I would add that running too fast or trying to use dull bits result in overheated which make's sharpening and staying sharp more difficult.(quoted from post at 18:17:50 05/01/21) High Speed Steel (HSS) is needed for a good drill bit, but that's a broad & over-used term. You generally get what you pay for in drill bits. Knowing how to keep them sharp, the correct speeds to run them at, and good drilling principles, will allow you to use that bit for years. Once a drill bit loses it's edge, it is tough to cut steel, and if you don't know how to put an edge on them, you'll be back to the hardware store. Find someone who can teach you to grind a drill bit, or invest in a good sharpener, and, above all, learn what makes a drill bit work and what a properly sharpened bit looks/measured like.
