Onan Generator
Just picked up a Onan 6.5 nhd-fb/1m from a box truck and the engine end sets a lot lower than the generator end when the truck was level. Is this correct or should I level the unit? The picture shows it on my table and you can see the tilt in the frame.
Also do they make a propane conversion kit for it.
Yup, blame it on ethanol. How would it get to the rubber mount? I would guess more likely old age and vibration. I have been using e-10 in EVERY engine I have and have yet to have a problem.
Those do sit at an angle. You should be able to move it slightly. It should move while cranking then smooth out while running.
When I decided to convert my Onan cck to propane, the folks at propanecarbs.com were very helpful.
