1946 BN IHC
??? Is it possible, wise, economic, and practable to re work the distributer that has no points, electronic I think, and install points? Would the outfit gain better fuel milage or not?
There are still HEI's out there on the road doing their job after 45 years. They are very reliable. New ones are still available, and the aftermarket produces high performance versions that appear in race cars. I wouldn't switch back to points, but if you do, a steel resistance wire or ballast resistor would be needed to reduce the voltage going to the points.(quoted from post at 13:53:22 12/19/18) ??? Is it possible, wise, economic, and practable to re work the distributer that has no points, electronic I think, and install points? Would the outfit gain better fuel milage or not?
(quoted from post at 10:42:40 12/19/18) > Would an 83 have advance in distributor, or computer?
I'm not sure. According to <a href="https://en.wikipedia.org/wiki/High_energy_ignition">this article</a>, knock sensors were introduced in '78. But it doesn't say when GM went to true computerized engine control. Should be easy enough for the original poster to figure out; the non-ECM distributor should have a vacuum advance.
(quoted from post at 17:38:36 12/19/18) > NOT quite so clear-cut! In that era (ealy 80's), GM had "ESC" (electronic spark control) that could RETARD timing if it "heard" knocking, but the distributors still had vacuum AND mechanical ADVANCE.
Yes, but shouldn't the presence of a vacuum dashpot betray that a particular distributor has vacuum (and presumably mechanical) advance?
