(quoted from post at 01:28:35 09/26/18) Every small engine I own including chainsaws you want hi-test gas. Chain saw 2cy mix, I mix one bottle of mix to 3/4 qt. of hi-test gas.
(quoted from post at 01:16:47 09/26/18) what gas do youings use in chain saws
(quoted from post at 23:32:25 09/25/18) 87 octane regular no ethanol.
(quoted from post at 09:26:21 09/26/18) after destroying numerous small engines fuel systems, i now run premium gas, it doesnt have the junk in it that regular does, then i buy the stihl ultra brand oil mix, so far stuff is running right
Define hi-test gas?(quoted from post at 23:28:35 09/25/18) Every small engine I own including chainsaws you want hi-test gas.
(quoted from post at 11:31:22 09/26/18) What sort of problems were you having ? Our stuff has not been completely trouble free either. But what ones have had issues I can't see how the gas caused them ? My chain saw got to where it would not idle but it is pretty darn old too. New diaphragms cured that. Everything looked clean inside. Mom's main lawnboy mower I've had to take the carb. apart on it as it has a regular float type but it seems to of gotten dirt clogging it up ? Got 2 other lawnboys and they don't seem to have that issue ? Mom tilts hers up to clean under the deck and I think that lodges dirt in where it should not be and clogs it up. These are all real old too.
(quoted from post at 07:39:46 09/27/18) I have also used Stabil and did not do what they said. About 10 years ago after having a number primer bulbs going bad my Echo dealer told
me to try Briggs & Stratton fuel stabilizer...
