Have any info on a Champion HR210-6cc compressor?
Rogmeyers
New User
I was given a Champion HR210-6cc Compressor. One slight problem there is no electronics box. Power cord is just hanging out of the Baldor motor. No on/off switch, relay or caps. Anyone have schematics for this box?. Thanks
There should be a tag on the motor showing the positions for the leads, high or low voltage, and rotation if single phase.
Once the motor wiring is known, the rest will connect as any compressor would, with a pressure switch directly controlling the motor (single phase) or the pressure switch controlling a magnetic starter and overload relays (3 phase).
Some compressors utilize an unloader valve in the pressure switch for easy starting. This would typically be a 1'4" copper tube coming from the head area to where the pressure switch would have been.
Be sure there is also a safety over pressure valve somewhere on the tank.
That looks to be a well made compressor. There may be some problem with it being it was stripped of some components. Don't give up too easy, it is probably repairable.
Compressor Info
