Stan in Oly, WA
What do you call the kind of gate hinges in which the piece on the gate---a strap on a wooden gate or a clamp on a cyclone fence gate---is formed into a vertical hole into which the pin on the gatepost is inserted? The "pin" as I called it is usually an upright cylinder about half an inch in diameter (more or less) and about an inch high. It may be at the end of, and at a right angle to, a threaded shaft which screws into a wooden post, or part of a clamp which bolts onto a metal post.
This is an annoying problem which happens fairly often to me. I would like to research something but I don't know what it is called. It's hard to begin researching something that you don't know the name of.
Stan
Stan
