Rear Tractor Rims 1938 JD B
Nella
New User
I need new rims for a 1938, JD B tractor. The rim size is 10" X 36". I DO NOT want new rims to have the safety rings. Where do you find rims (10" X 36") without the original safety rings? Thanks!
www.millertire.com 36 x 9 Flat Base Rim Unpainted
Flat Base Rim Unpainted Rim width is measured inside, bead to bead, NOT outside to outside. Reuse your "Center Disc" or "Brackets" Inside diameter is 34". For 8.3-36 and 9.5-36 tires. Check your rim style and tire size before... $156.00
