What were these used on
grandpa Love
More junk store stuff. Just curious.
Don't know but you can still buy them from the better toolmakers. The striking end is now rectangular. It's made for the final tightening to be done with a hammer.
That one in the middle looks like the one I borrowed to move the wheels out on my 986 and broke it. Had a hard time finding another one. Wasn't cheap either.
Yes, I have one size 1-5/16 that will fit on the wheel clamps on my 986. SnapOn, nearly worn out, About all you can easily use on the inside clamps
Every compressor station on the pipeline had a full set. 3 1/4 inch was used often with a sledge hammer. Oh the good old days.
Slug wretches. We Pipefitters used them in refineries or powerhouses to remove flange bolts that had rusted tight because no one had used anti seize on the bolts when assembling them. I remember climbing over 50' in the air on a catalytic cracking tower to break flanges open using these type of wrench's. Fun, fun, fun! Builds upper body strength!
I always knew them as STRIKING wrenches.
Evidently there are differences between striking wrenches and slugging wrenches, but the differences are unclear.
Proto makes both, some are 6 point, some are 12 point. ...Some are offset, some are straight. ....Some are heavy-duty, some are not.
There seems to be undefined differences. ....Maybe based on length or shape ????
My first encounter with them was on an offshore drilling rig in 1981. They were called hammer wrenches. Two man operation, one guy held a rope tied to the handle to keep it snug and the other guy had a 12lb sledgehammer. I have been hanging from a air tugger 80ish feet above the water on a well head tightening bolts with nothing between me and the water. Fun times of my youth.
The 2 outside ones we called slug wrenches, the center one is designed to put a tubular extension on. Used slug wrenches a lot in the paper mill, when loosening the nut on a 2 inch bolt an ordinary wrench would have to be 8 feet long!
Granger sells a wide variety of slug and striking wrenches. Both types are made to be pounded on and both come straight and offset. The slug wrenches are heavier made.
In the ski industry, they were used on Riblet bullwheel hub clamp bolts. Lots of time there?s no air or electricity around to power an impact wrench.
My first experience with those was working on a Bucyrus Erie 1260 walking dragline back in the late 80's. Old dragline mechanic I worked with would tell me to beat on it until the nut wouldn't move and then beat on it some more and it might be tight enough. We have got a big chest of them at work but we don't use them much anymore as management has deem them a safety hazard. We now have hydraulic torque wrenches to use on large bolts and nuts. I do have a couple in my shop and they have come in handy over the years.
