Best sneaker for wet conditions
Rkh
Can anybody suggest a good pair of sneakers to wear in wet grass conditions? In the northeast, it is damp in the mornings & have had no luck finding a pair of sneakers that can handle wet conditions.
You need what would be called a deck shoe. There the type of shoe used on boats etc. There made to handle being wet and still give good traction so slipping around on a boat is less likely to happen. Most any sporting good place or even some boat dealers will have them
(quoted from post at 16:24:15 08/22/18) Can anybody suggest a good pair of sneakers to wear in wet grass conditions? In the northeast, it is damp in the mornings & have had no luck finding a pair of sneakers that can handle wet conditions.
Yeah, rubber barn boots!
I haven't found any good sneakers that are good for wet conditions and don't get soaking wet. I just wear my logger boots that are water proof.
Those canvas deck shoes but give them a really good coating of Scotch Guard. Keeps them much dryer.
I have a pair of muck boot co. muck shoes, they are same thing as a muck boot but in a shoe. They are good for chores, comfortable, tough and have good grip in mud or slick grass. They do have some insulation but probably not enough for extended winter time use.
Teva water proof hiking shoes.. Ive been wearing these for a few years just because of the problem with moisture.. Early morning out in dew, etc. etc..Im hard on shoes anyway.. usually last one year. I was out this past spring in a thunderstorm that hit when we had a few bales left in the field.. Got soaked but feet stayed dry.. I was impressed..
They are not cheap though but protecting my feet from athletes foot from sweating and moisture is a must with having diabetes..
Check out Merrell, they make a shoe called the chameleon. I've had a pair for about 10 years now, pretty beat up at this point but still waterproof and the tread hasn't worn out either. No holes, I wear them every time it's wet when I don't feel like wearing the muck boots. They still make the same model, about time for another pair so when these do give out, I'm all set!
