Gas pump hose
ldj
Looking for gas pump hose without the ends. All I can find has the ends on it. I want to makeup my own length and use hose barbs. I have looked and can't find any. How about heater hose? Would it work for any time or would I just be wasting my time?
No heater hose will not work.
Push Lock hose will work. Reasonably priced, available up to 3/4". Not sure what the wall thickness is, if it will work with your connectors. But it is designed to work with their barb fittings, just push it on, no clamps.
Push Lock Hose
(quoted from post at 17:20:26 08/21/18) Looking for gas pump hose without the ends. All I can find has the ends on it. I want to makeup my own length and use hose barbs. I have looked and can't find any. How about heater hose? Would it work for any time or would I just be wasting my time?
https://www.mcmaster.com/#flexible-fuel-hose/=1e9b3yt
Is this for your visible pump you were looking for tank to pump hose for also?
If yes and you do not yet have the fill nozzle, I will make you a deal on a brand new one.
It is not "period correct" but it is new and I am sure the price would be a deal. It has 1"NPT female connection.
(quoted from post at 18:58:03 08/21/18)
As a mater of fact it is for that visible pump. You have a good memory. I have found local where I can get the hose I need.
Gates use to carry it in their industrial line of hoses. i used to supply a few local garages with it in the old days. It had a static wire in it I belive also
I tried heater hose on my log splitter running hydraulic fluid between the reservoir and pump inlet. Nope. Started melting. Went to Lowes and got some
Tygon (brand) clear vinyl tubing which worked.....pressure rated to 65 psi max., non-reinforced.
Probably the easiest way would be to
but a transfer pump hose and cut the
ends off, do make sure it has static
wire connected as well
I did find a place that sold it without ends and by the foot. BUT it was $4.71 a foot. Markct had the best Idea. The made up hose it $23.99 for 10'.
