So I pulled the old dead motor out of where it was. This it he info it had on it
HP 6SPL HZ60
V 230 PH 1
RPM 3450 Code J
A 15.00 SF1.0
AMB 40C FR 56
Non reversible motor compressor duty
While most of what it says I understand but some I do not. I also has nothing on it as to which way it turned so that still is no help. I know the 6SPL and the A at 15 does not fit it being a true 6 HP motor. The AMB 40C means nothing to me. Code SF and FR also mean nothing to me. Compressor it self has no tags or other such info on it. Only thing I found was a number cast into the cylinder block but did not write it down.
So does this help you help me??
HP 6SPL HZ60
V 230 PH 1
RPM 3450 Code J
A 15.00 SF1.0
AMB 40C FR 56
