Andy Airgood
I?ve got a rear tractor tire that had fluid in it which was causing it to rust. I had the tire removed and found the metal surface under the tire was rusted and badly scaled. I spent a day grinding off the corrosion/rust. It was one of the dirtiest jobs I?ve done. Because of pitting I was never able to get a perfect bare metal surface but it was much better. I then put a heavy coat of rustoleum rusty metal primer on it. I checked it the next day and found little rusty water beads on it that appeared to be coming through the primer. I then put it in direct sunlight for several hours and then put another coat of primer on. Once the paint dried I found more water beads on it. Any ideas why I?m getting water beads and how I can get rid of the moisture?
