sheep with bloat
Call the Vet, you need expert direction, a sick sheep is usually a dead sheep unless you get the help you need pronto. jmho gobble
If sheep are anything like goats they can go from the bloat causing discomfort to causing death in a matter of hours. Seen it happen in our herd. Call the vet ASAP!
A vet told me this for cattle it might be hardware simply put it hurts to cough . oddly enough with a chronic bloater a magnet will solve the problem.Look also at what there eating some plants are more prone to bloating then others. Get a vets advice but if its bloated mow get it treated right away.
Vet told me once to use baking soda. They also have anti gas meds that can help.. When he started talking running a hose down their throat into the stomach to relieve gas I told him to come out and do it..
He also told me that sheep eating to much Clover or Alfalfa is the #1 cause of bloat. Especially during the Spring when they were first turned out to pasture.
Your right about alfalfa and clover you can
feed it but it's awful tricky.First never
turn them out hungry feed dry hay and let
them fill up on that if they go out hungry
they will eat to much. A mixed stand with
grass is the best and let it get higher than
the clover before grazing.
It can be done with experience .
Yup. Not purebreds or anything fancy, though. And by "herd" I don't mean a bunch of them - we have just a handful of does and one buck. Enough to give the kids some responsibilities and ownership with the chores, though.
May sound odd but get out there and chase them around.
If you can get them running it helps release the gas.
Get some bi-carb in them ASAP. Generic Pepto Bismol works fine or drench with baking soda and water mix. Keep them off their sides and get them up and moving.
...no malice or forethought intended, but....I had sheep for years and I believe they are born looking for a place to die! I'd say, "start digging a hole."
SUPER EASY!!! My daughter was doing it when she was twelve. You just need need the correct tube. You put the end in its mouth, and it will immediately start to swallow it down. When the end gets in the stomach the gas comes out the tube.
Dairy cows will bloat also.
It's been along time but if I remember right my dad used to what he called drench a cow.
He would take warm milk and mix it 50-50 with kerosene, put in a long neck bottle, like a large Vernor's bottle, and tip the cow's head up in the air and shove the bottle in her mouth as far as it would go and let it drain.
