TractorLinks.com
Tool Talk Discussion Forum
Good Grease Gun tip?
part time pete
06-13-2018 05:31:41
I've been having a heck of finding a grease gun tip that doesn't leak, so I went to NAPA the other day and bought a "heavy duty" tip. It didn't leak, but you can hardly get it off the fittings - I actually broke one fitting off trying to pull the grease gun off, so I went back to my old leaky one
Is there a good tip available?
Thanks
Pete
kcm.MN
06-17-2018 08:09:13
 Re: Good Grease Gun tip? in reply to part time pete, 06-13-2018 05:31:41
Washes his hands a lot. *lol*
JML755
06-17-2018 04:31:00
wow, I'm curious: What do you do?
Brown Swiss
06-17-2018 04:17:27
I go through a couple a week at work, and use Milwaukee brand tips. Don't know if they are the best, just what they get. Did have the lock n lube but couldn't get in all the places to grease! We use some grease, a 120 pound keg lasts 2 days! LOL
Elmo
06-16-2018 09:20:23
I keep two grease guns, one has a rigid tubing in place of a hose. The other is a Lincoln with a flexible hose equipped with a lock and lube. I love it! The Lincoln was my dads and it is at least 65 years old and works like new!
DoubleO7
06-14-2018 14:10:49
I have grease fittings you can't put your hand on due to location.
So an LNL does me no good.
My rigid tube grease gun with the index-able nozzle end works better for me.
SVcummins
06-14-2018 22:38:36
 Re: Good Grease Gun tip? in reply to DoubleO7, 06-14-2018 14:10:49
I donít really like the design of the lock n lube either itís way to big to get to most of my fittings . Iíve seen this style I like better
jgayman
06-15-2018 12:59:51
 Re: Good Grease Gun tip? in reply to SVcummins, 06-14-2018 22:38:36
> I donít really like the design of the lock n lube either itís way to big to get to most of my fittings . Iíve seen this style I like better ēUntitled URL Link
I have one of these. The problem with the Univerco is that if you build up any pressure at all on the coupler it is impossible to remove. You then have to loosen the hose on the grease gun to bleed off the pressure. The company even came out with a cludgy valve that attaches to the back of the fitting which allows you to bleed pressure. Of course this make it very unwieldy for normal everyday use.
A second problem with the Univerco is that if you get even the slightest bit of debris on the tip it blocks the ball bearings from retracting and you cannot get the coupler to stay attached.
This one is an epic fail I'm afraid.
SVcummins
06-16-2018 23:07:02
 Re: Good Grease Gun tip? in reply to jgayman, 06-15-2018 12:59:51
I worried about the exact things you mentioned and at 30 dollars ive decided I really donít want to try it unless itís on sale for half price . The best thing Iíve found is keep grease zerks in good condition replace em when they start leaking more grease than goes in the fitting and replace the gun tips when they start leaking and wonít stay on . I bought some grease zerks at harbor freight once worst mistake I ever made they must have got the pattern from a 50 year old wore out zerk they wouldnít take grease without leaking everywhere ended up throwing the whole kit in the garbage can . Went and got a set of zerks from John Deere 4 times the money but they work I also have a case ih set that I just bought that works great as well either set was around 35$ 100 zerks in each set the case set actually had a couple of style zerks that come in handy
DScott
06-14-2018 12:00:18
I had the same problem. Changed to the Lock N Lube and wished I had done it years sooner.
part time pete
06-14-2018 04:58:03
Thanks guys! I guess I know what I'm getting
Mountain J
06-13-2018 22:36:42
I vote for lock and lube too but has anyone wore one out yet cause I think I have mine started leaking suddenly a couple weeks ago now I have to get a new one
jgayman
06-14-2018 13:00:25
 Re: Good Grease Gun tip? in reply to Mountain J, 06-13-2018 22:36:42
You can get a seal kit which comes with new jaws for $7.85. That's a lot cheaper than a new LnL. They ship an extra seal kit with each LnL now but back when I first bought mine they did not.
Harold Hubbard
06-14-2018 10:11:09
Mine came with a set of replacement jaws and seals.
RobCons
06-13-2018 17:24:21
Another vote for LocknLube. Love mine.
Harold Hubbard
06-13-2018 16:36:59
THE ONLY ONE IS LOCKíNíLUBE!!!
CCer
06-13-2018 13:50:43
Add my vote for Lock n Lube. It's the Best.
jgayman
06-13-2018 13:04:39
Did you know those couplers are adjustable? The end unscrews to lessen the tension on the fingers. Most however come screwed on so tight from the manufacturer that you think it is going to break before it loosens. I usually have to clamp the nut part in a vise and then use vise grips on the barrel to loosen. Once loosened you can try to find a happy medium between leaking and going on and off the zerk easily.
BUT!!! The true solution is the Lock 'N Lube coupler as the other poster suggested. Once you try one of these you will wonder why you suffered so long. Yes, it costs $29 but it will be the best $29 you ever spent and actually makes greasing fun and mess free.
jniolon
06-13-2018 05:35:38
try this one Pete, you won't go back
https://www.amazon.com/LockNLube-Grease-Gun-Coupler-Lock/dp/B00H7LPKKU
