Super H Mike
I have an older Century arc welder that I am having trouble striking an arc with, and when I do get it going it will go away after about 5-10 seconds. Can it be as simple as moisture in the rods?
(quoted from post at 15:14:07 06/04/18) Also, how can I store my rods better without investing in professional equipment?
(quoted from post at 02:40:06 06/05/18) FWIW, 6010 and 6011 are pretty much immune to moisture problems.
As for 6013, it makes a nice bead but has poor penetration. Try some 7014, you'll like it.
Was what you were welding clean? If not, that could be your problem. But heat, travel, rod angle all come into play too. Like others have said, there are better electrode choices available.(quoted from post at 22:14:07 06/04/18) Great advice ! Fresh 6013s and I am welding again! Two more questions, I noticed I had some "craters" after chipping the slag off. Is that the material, technique, or too hot, what do you think? I was welding a new flex joint onto an exhaust pipe from a car. I had it on 90 amps DC straight polarity. The pipe was off the car and in the vise so it was basically flat work. I was able to fill the craters in ok but wondering what was causing it. I am not a pro by any stretch but always seem to get the jobs done. Also, how can I store my rods better without investing in professional equipment?
