Cheaper alternatives for art equipment
Stan in Oly, WA
Art equipment is an area in which items sell at a large markup. I believe that this is because a lot of people who have plenty of free time love the idea of being artists. Before they find that they don't have the talent for it, or don't have the perseverance, there is one part of the process that they're already good at---buying stuff. A tool which is in wide use in industry or by tradesmen will cost a lot more if it is sold as an artists' tool on an artists' website or magazine.
My wife is a serious artist who is investigating a process which is different than what she has tried before. It is called encaustic and it involves applying pigmented melted wax as the medium rather than paint. She needs a small heating iron, like a dry iron (not a steam iron), iron shaped but only about 5 square inches in size. The other piece of equipment she needs is a wax melting pot. A lead melting pot for bullet casting would be perfect except that I haven't been able to find out if those can be turned low enough for wax. Any information and suggestions would be appreciated.
Stan
Hello Stan,
I have one of those lead melting pots. Now you got me thinking. I'll have to see if mine has a temp control knob. I think NOT, will look in the A M
Guido.
Stan in Oly, WA- I had a Lyman lead melting pot, it did have a rheostat to adjust temperature. It gets very hot. When I want to melt wax, I just use a double boiler on the stove top.
The melting point of pure lead is over 600 degrees, so it may be too hot. May adjust lower, though. How about a clothes iron mounted on a bracket of some sort?
Go to WalFart and get a crock pot.
Size of her choice. They are cheap enough to experiment with.And they are made in many sizes.
They also have little miniature ones that are for that pooporee stuff or scented waxes for odor control, etc.
But maybe she wants something that will hold several colors at the same time?
I wonder if a counter top induction burner with several metal was pots on it might work?
For melting wax, try an electric frying pan from a garage sale. We used one for dipping the teeth on saw blades. The dipping medium was a wax/plastic compound that melted easily at very low heat. As for an iron, IIRC, Brownell's Gunsmith supply in Montezuma, Iowa used to carry a small, dry-heat iron similar to what you describe. It was used for applying stick shellac for gunstock touchups. That was a lot of years ago, but they might still carry it. unc
Stan,
You may want to check at a beauty supply for a "Facial Wax Pot".
My wife is a retired cosmologist and used one in the shop for years.
Dsmythe
Get a crock pot from Walmart or where ever. Nothing fancy needed, just sized for whatever you are doing. I use a small one to melt candle wax all the time. It keeps it liquid without burning or making smoke.
I have also used it to melt down crayons and with assorted molds and old cookie cutters, kids can make crayons in any shape they please, using a collection of short stubs and broken old crayons to make new ones. (Can be a nice rainy day project)
Thanks for the suggestions and advice everyone. Looks like a Goodwill or craigslist crock pot would be the cheapest alternative.
Stan
For you small iron you want a "monokote iron" which is used to apply heat shrink covering to model planes. I wore about about three such irons out over the 30 years I buit and flew the planes.
Amazon has them - one that looks good is about $23 - a "Hangar 9 Sealing Iron." Has a thomostat and goes up to 450 degrees.
