Tool Of The DAy,
guido
Hello,
I have had this tool for a long time. I have no idea where I got it. Number 336 Greenfield made in the U.S.A.
GUIDO.
(quoted from post at 21:05:57 05/16/18) Hello,
GUIDO.
did they make them that long to help get them plumb ??
Greenfield makes the taps and dies everyone wants. The cost of Greenfields is what drives most people to HF.
It's for threading a set screw hole in a gear, pulley, or sprocket hub that is too close to turn the T handle.
Or any other application that requires a deep reach.
Well in the case of not having a long tap wrench like that you can always get a pulley tap also called extended tap, McMaster Carr has them.
I bought a set of 4 or so ? similar to that at a yard sale years ago. The ones I have the tap is made to the handle soldered in or something ? Handle at the tee part looks just like yours. These let you go way down in a deep hole.
Dad had a collection of differnt sized T handle for taps when he worked for a company that rebuilt International heavy mining equiptment. He rebuilt cylinder heads for them.
I was a small kid then. But remember everything was "pay" except for the T series dozers.. Pay Hauler, pay scraper, pay grader, pay loader.
Nothing like hearing a freshly remaned. T25 dozer engine running under full load on a dyno for 24 hours.
I remember at work it was usual to press a nut on the end of the tap using a bench vice & then a socket & extension & ratchet used to run the tap!
I still have a few taps with nuts still on them.
Bobcatz
I have a whole set with nuts pressed on them, used them with an impact, you would be surprised how good it works. use good lube, and reverse often. I learned this from an old time shade tree mechanic.
