Need fuel dispenser hose
I have a 12 volt fuel pump on my transfer tank and need to replace the just-like-new hose. It leaks past the crimp unless you hold the hose just right. My question is - what brand, other than the original leaky FilRite, doesn't leak? Suggestions? Experience? Thank you.
Tuthill Corporation and if you can find a company that sells Liquid Controls should have them. Go into a gas station and look for a sticker on the pump who installed it. Not the pump brand.
Don't last long....a couple years & material hardens and leak. Just typical 'todays crap' products.
Go online and type in gas pump dispenser hose and you will find a number of companies selling it.They handle different grades of hose and fittings from chrome to brass.
I went to a local hydraulic hose supplier and asked them what would work well. They came up with a Gator hose that is just about perfect. They also installed the connectors I needed. The hose markings just say Gator WP300PSI Air/Fuel 5/8".
It is as flexible as one can expect and 100% better than the hose that came on the pump.
I bought mine at TSC. It only lasted about 20+ years. It got brittle so I went back to TSC and bought another. Work fine.
