Mower disc removal
ed1
Any of you guys got a trick to take the "stump jumper" off my TS mower? I am replacing the seal and can't get the disc off. I wil try to work out a
puller of some kind, but thought if you guys had a special trick I would use your knowledge and thank you for your time.
Thanks,
ed1
(quoted from post at 21:08:47 05/05/18) Any of you guys got a trick to take the "stump jumper" off my TS mower? I am replacing the seal and can't get the disc off. I wil try to work out a
Thanks,
ed1
uller..........just last week
That is why there are so many that instead of pulling the lower part off, they just fill the gear box with grease. It works fine and is not nearly as much work to do. The seal will possibly get torn up again while brush hogging. Just my thoughts, Keith
