Well, it's a tool for a barber
I just bought a F&F Koenigkramer Reliance model Barber chair. I can't find a tag on it for model #, date or anything. I have looked for forms about barber chairs, found a few that aren't active and closed. It is low on oil so I googled and found several conflicting answers. I used a wire and it appears to have transmission oil in it now, but what kind? There is oil for Fords and if you dan't use Ford I hear you will have a problem. So what oil should I use? I don't see evidence of leaks, so where did the oil go? I know it's low because it will raise a couple inches and it quits and I hear it sucking. Maybe someone is better than me and knows where a active forum is. Any help appreciated.
