Or, I buy junk.
The paint was like tree bark. So I cleaned and painted the lathe. The handle for lifting the motor was broke. I welded it and it works. The tail stock was froze up, but I got it loose and it works. A jaw is broken on the chuck. The chuck is made by the Union Mfg. Co. I have not been able to find any replacement jaws and one post said that as old as it is, replacement jaws will be tough to find. So I may need to replace the chuck. I also have not been able to remove the Chuck from the spindle. I removed the cross slide gib this morning and then cleaned and re installed it. From what I could tell, I have tightened the adjustment screw in as tight as it will go and it still does not stop the cross slide movement.
I saw where a person can buy a copy of the original "CARD" for $25 and that it will have the details on it that will allow you to order the correct replacement parts. Is it really worth it to buy that Card?
TY
SDE
TY
SDE
