What is it?
redtom
Found in my uncle's basement. He was a poor farmer and never had much so I can't imagine what this is.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto13307.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto13308.jpg"/>
Saw jointer, for hand saws and crosscut timber saws, anything with a straight blade. You clamp a file in it, it holds the file square to the saw blade as you lightly file the points of the teeth. This makes the teeth all the same height, with a little flat spot at the point. Then you sharpen each tooth until the flat spot just disappears.
There is a similar tool for circular saws, I always cheated with skillsaws, put the blade in backwards, and just touch the concrete floor with it.
GOOGLE found me this interesting photo of what looks like the exact same tool with a mfg's name on it:
<img src = "http://hus-saws1.wkfinetools.com/atkins/tools/cross-cutSawTools/0_img/Excelsior%20Saw%20Tool-530.jpg">
And these instructions on it's use:
<img src = "http://oi68.tinypic.com/2emevds.jpg">
Thanks for the instructions Bob. I have a couple of those but never knew exactly how they were used.
