Hex I. D. washer source?
Bob
I need a couple of 9/16" ID. hex washers for a project, 1/8" or 3/16" thick, O.D. not critical.
I thought this would be an "easy find" on the 'net (McMaster, etc.), but all I am seeing are manufacturers selling in large quantities.
Anybody know of a source for a small quantity?
Thanks!
Meant to attach this drawing...
<img src = "https://www.seastrom-mfg.com/images/5732_engr.jpg">
Any metal shops around that might have a hex punch? I know we can all different sizes/shapes at work. If they have one, they probably could punch them out pretty quick.
I don't mean to side track this but, what are these used for? I had to go search them because I've never seen such a washer. For the life of me, I'm stumped as t why this washer needs a hex hole. Please learn me something.
I agree that it forces the washer to rotate with the shaft, assuming the shaft rotates. I could see it providing resistance to rotation through friction against whatever surface it contacts. Still curious.
Simple version, 3/8" bolt is being used as a pivot point, lever pivoting on bolt has nylon busing inside.
For long life, it's best if the bolt is held stationary and the bushing pivots on the bolt.
A washer with a 9/16" hex ID welded to the structure will hold the bolt from turning and instead the nylon bushing will take the wear.
Start with a 9/16 deep well socket and make as many as you need. Parting tool in lathe would be best but could be done with a drill press and Dremel cut-off wheel.
(quoted from post at 23:16:33 03/20/18)
Why not just a piece of square stock welded next to one flat of the hex head?
Would do the same thing.
