mjsnodgrass
tonight I changed oil in my welder, and as it's been a few years ,decided to change the antifreeze as well. opened radiator drain, and the antifreeze looked, and smelt like new. but I didn't drain as much as I thought I should. I opened the petcock on the engine. nothing cam out. put a little air to the petcock, and the worst looking brown antifreeze came out of the engine. tomorrow i'll pull the thermostat and flush the system. anyway, the antifreeze looks like it came from 2 different machines. i'm confused as to why the anti freeze wasn't all green, or all rusty looking. why didn't it mix. the welder has a temp gauge on it, and doesn't overheat. even if the thermostat was stuck shut, the bypass hose should of allowed enough coolant through to the radiator. that should of mixed it. I can't believe what I saw tonight. can anyone explain it to me? thanks for your help
