This is in reference to my earlier post about the Husqvarna 359 that would idle high then die. This will be the last update I promise...First, thanks to all that replied to prior posts. It ended up not being an air leak. It was a bad carb, evidently the original WALBRO carb has an accelerator pump within it that tends to go bad. The parts are not available to replace the pump so the whole carb has to be replaced. You can tell if your carb has this pump by the little brass plug on the end of the carb. I replaced with the recommended Zama carb and straight out of the box it ran great. Just thought you husky guys might like to know.
Thanks Dan
Thanks Dan
