Another Tool
Brian G. NY
This is a pretty easy one.....not used much any more except by us guys with antique tractors and cars.
These two other tools will give you a big hint as they all work together nicely.
Battery tools top one is a cleaner for old style batt. ends other is a puller for same pliers for corroded nuts on cable ends
Bingo!
It's supposed to be a combination terminal spreader and "cleaner".
It works really well for opening up the old style terminals but not really well for cleaning them.
I use the battery pliers for a lot of things as they have lots of leverage at the jaws.
They work really well for removing rusty brake line fittings.
Second pix I never found those pliers to be of much use maybe I will give them another try... BTW I always wondered what that doohickey was on the end of the spreaders.. Thanks for posting I can die in peace now :)....
That "doohickey" is a pretty crude little device to keep the handles closed when not in use. Doesn't seem important enough to go to the trouble. LOL
