flembo
Someone posted pictures of tools that were modified to suit so I thought I would show some of mine both home made and modified. In the first picture the 4 on the right are store bought Distributor wrenches, the rest were modified to suit notice the right angle pliers. The last 2 pictures were home maid lift bolts and a slide hammer to pull bushings I made other attachments for the slide hammer as well (not shown). the socket welded to the bar stock was to hold a nut still, while turning a screw in the center I think made while replacing Macpherson struts on a Mopar. The lift bolts had to come home after Osha entered the work place. When I first started work in the late 60's we were able to use home made lift bolts and rope slings I remember going to the tool crib and getting a length of rope then tie a square not in it to form a sling. When people say Osha is a PITA, ya they are somewhat right but it was also needed they just go to far with some things.
