Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Snap rings?
PJH
02-09-2018 08:22:53
How do you put them back on the shaft without scratching the seal surface?
hd6gtom
02-11-2018 19:37:34
 Re: Snap rings? in reply to PJH, 02-09-2018 08:22:53
JDEM has a picture of the correct tool. Lot of those used on auto tranny's. I picked up one at NAPA last year.
d7fever
02-11-2018 08:10:38
Just bought one of those for 15 bucks at car quest.
PJH
02-10-2018 07:34:56
Thanks for all of the good advice. I ordered one like Moresmoke recommended. I'm saving this post for the future - just in case. Everybody needs two :~)
Ted in NE-OH
02-09-2018 17:31:07
That is an internal lock ring , it goes into a cavity, otherwise the end points will hurt you. Stare one end by pushing it down into the cavity and then work it around until it bis completely into the grove in the cavity.
JDEM
02-09-2018 17:42:30
 Re: Snap rings? in reply to Ted in NE-OH, 02-09-2018 17:31:07
I have never seen an "internal" ring like that. No way to remove it the way the ends are shaped.
Stephen Newell
02-10-2018 04:32:34
 Re: Snap rings? in reply to JDEM, 02-09-2018 17:42:30
That's because it's an external speared end snap ring.
JDEM
02-10-2018 06:12:50
 Re: Snap rings? in reply to Stephen Newell, 02-10-2018 04:32:34
Yeah, I agree. Just wondering why Ted is claiming otherwise.
JDBRIDER
02-09-2018 19:39:47
There is one like that on a shaft behind the flywheel on my 45 AR. In order to remove it I drilled a hole behind it thru the ring gap. The gap was bigger than the one on this ring.
gab
02-09-2018 12:57:53
The one on the left.
JDEM
02-09-2018 11:49:44
Just buy yourself a parallel snap-ring pliers. Made for the job. I have been using them for 50 years.
I have a bunch of them. My favorite are Proto (now Stanley) 251G. Made for exactly what you want. John Deere sold them. Ford sold them. IH sold them. OTC sold them. PROTO sold them. Stanley still has them.
Russ from MN
02-09-2018 10:13:56
You could wrap a piece of thin shim stock around the shaft, or a piece of a pop can!
Brian G. NY
02-09-2018 08:39:25
[quote="CVPost-PJH"](quoted from post at 17:22:53 02/09/18) How do you put them back on the shaft without scratching the seal surface?
The only place I can see where the snap ring might scratch anything is at the two ends.
A little "rounding" at these two points should take care of that.
Prudent use of a good set of snap-ring pliers will help as well.
I've never experienced the problem.....seems most shafts are too hard to scratch easily.
PJH
02-09-2018 08:56:57
 Re: Snap rings? in reply to Brian G. NY, 02-09-2018 08:39:25
Brian - can you recommend a good set of snap ring pliers? I've read through the archives, and it seems like they don't exist for this type of ring. Folks seem to use my "whatever works" method for removal, which includes small screwdrivers and knives. I'd like to open them up, slip them on, and release them in the groove without sliding and prying them into position.
Moresmoke
02-09-2018 09:30:12
 Re: Snap rings? in reply to PJH, 02-09-2018 08:56:57
I've got a couple different pairs. One set will handle the 5" rings on tractor axles.
PJH
02-09-2018 10:23:39
 Re: Snap rings? in reply to Moresmoke, 02-09-2018 09:30:12
That's exactly what I'm looking for!
Thank you!
