TractorLinks.com
Tool Talk Discussion Forum
Runaway IH B275 just started....
Boomstick
02-09-2018 06:16:15
I parked my B275 diesel the other day and just as i went to turn it off it had an increase in the revs.It was always kind of sluggish so this took me by surprise.
From research i thought it might be rings allowing oil from the crank but its not blue at all its black smoke ....The only thing i found that i thought it could be was a governor...But im really not sure..It immediately goes into high revs and the kill switch can shut it off or keep it going ...
Boomstick
02-09-2018 09:30:20
 Re: Runaway IH B275 just started.... in reply to Boomstick, 02-09-2018 06:16:15
Thanks guys i will check those out...appreciate the input...
Al Baker(pumpman)
02-09-2018 08:26:37
If you have the pump that is pneumatic make sure to check the air cleaner. If it is frozen up with water or plugged up it will restrict the air flow and make it run crazy. Al
JDEM
02-09-2018 07:24:03
Is it an early or late B275? Early has a butterfly valve in the air-intake pipe that can get stuck open. Mine got jammed closed once with mud-wasps.
Early BD-144 has a CAV in-line pump box with four injector pumps riding on a camshaft and an air-governor like a old Ford Major uses. Governor hooks to linkage to a butterfly air-valve flapper in the air-intake pipe.
Later BD-144 has a CAV rotary-distributor pump with an internal centrifugal governor.
Bob
02-09-2018 07:13:45
Injection pump rack is stuck/frozen or pneumatic governor diaphragm is torn/damaged.
Boomstick
03-08-2018 12:25:17
 Re: Runaway IH B275 just started.... in reply to Bob, 02-09-2018 07:13:45
Thanks Bob you were dead nuts on......It was a torn Pneumatic Diaphragm....Heres a URL to the one I rebuilt and put on youtube.. https://youtu.be/uzrFzf72Dl0 Maybe this will help someone...It works great by the way...At first it didnt seem to change the problem it still revved high...But the next day I tried again and it idled like a champ...
