Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: OT home service electric panel upgrade
part time pete
02-09-2018 05:00:30
Check with your utility, but in many areas a three phase service gets billed at a commercial rate, whereas a single phase service gets billed at residential rate, which are much lower. As mentioned previously, a three phase panel and meter trim will also be quite a bit more expensive than a single phase.
As far as the voltages available from a three phase service - typically they are 120/208. Your single phase 120 volt circuits will be just that, but your single phase 208 volt circuits (two pole breaker, such as for your dryer) will be 208v instead of 240v. That won't bother your dryer - the heating element just won't get quite as hot. As far as single phase 208v loads, such as central air, most of the motors are dual rated anymore, so they can run on 208v or 240v.
All that being said, I think you would be better off installing a new single phase service, and getting a phase converter for your three phase loads. Pete
