TractorLinks.com
Tool Talk Discussion Forum
kohler crankshaft
gfj
02-08-2018 15:10:47
Anyone in western mo or eastern ks know of a shop that can turn a crankshaft for a k341 kohler 16 hp motor?
Jleus
02-08-2018 20:06:18
 Re: kohler crankshaft in reply to gfj, 02-08-2018 15:10:47
I've got a Kohler kt17 that siezed a rod at the crank and snapped it, cleaned the journal up with muratic acid, polished it a bit, and back to mowing.
buickanddeere
02-08-2018 16:29:35
. Shops that build garden pulling tractors are pro’s with K341 cranks .
gfj
02-08-2018 15:30:30
Yes it is a horizontal shaft. Do you have a price?
1970-1655
02-08-2018 15:29:30
Midwest Super Cub is located at:
333 Welton Ave.
P.O. Box 10 Welton, IA 52774
Tech line: 563-659-5276 Avalaible 9:00 AM - 5:00 PM Monday-Friday
Voice Mail Order line: 888-414-6983 Available 24/7
Dieseltech
02-08-2018 15:29:27
Did it get low on oil and old rod weld itself to the crank before the rod broke? If so just go to the hardware store and get some muriatic acid, use an old paint brush to coat the aluminum on the crank to dissolve it. DO THIS OUTSIDE AND DON'T BREATH THE FUMES!! Last several Kohler cranks I've had here were cleaned up that way, without being ground.
oldproudvet
02-08-2018 19:35:04
 Re: kohler crankshaft in reply to Dieseltech, 02-08-2018 15:29:27
I just did the same thing to a 16hp Briggs out of a MTD zero turn mower. MTD had a plastic (?) tube out of the drain pipe hole leading to the rear of the tractor to a fitting, making it a piece of cake to change oil. Only thing wrong with the system is the tube got to close to ex and burned in half, dumping the qt and half of oil in seconds. Both rods siezed and broke. It happened so quickly, the cylinders and pistons were as new. Time spent with the muriaric, rubber gloves and fan blowing over it eventually cleaned it off. The steel wool I was using disappeared quite quickly too. It miked perfectly.......
old
02-08-2018 15:26:25
Have you checked with the local O'Reilly's auto parts store they should be able to or know where it could be done. Is that a horizontal shaft engine?? If yes I have one
