Husqvarna 576XP and Stihl MS460 update
RBoots
Had hooked up the line that had come unhooked on the 576XP, and while I was hoping it would take care of it not wanting to idle down, I knew better, it didn't. I hooked it back up, and went out and cut with it for a few minutes. Once it was warmed up, it was just like it was before, wound right up still after letting of the throttle. So, I put it in my garage, and am gonna tear it down fully, and replace all of the gaskets, the crank seals, and all the lines just to be safe, and check everything else out while I'm in there. On the other hand, the MS460 I traded for that the guy accidentally ran with straight gas, has stepped up to fill it's spot for the time being. I've run a tank through the MS460, and it runs exceptional, very strong. I'll bet the guy that gave it away wouldn't have bought the replacement saw if he'd just put some mixed gas in it after it cooled down. I don't think it hurt it a bit...
Ross
Had a family member that bought saws off Ebay that guys said were bad and almost every one of them it was something minor and he resell them and made money.If he found a good saw he kept it for his side line tree business.
I picked up a Stihl 031 AV that had no fuel in it for free. The guy said he set it down and it died and never ran again. Oh well
The Husky sounds like an air leak some place. Could be the crank seal(s). Spend some time checking the carb to jug interface. Both the boots and blocks that are used can leak and give the exact symptoms you describe, so can a bad jug to crankcase seal.
Yep, I'll find it when I get it apart. I'm
gonna eliminate the jug base gasket when I
do it.
(quoted from post at 00:50:52 12/23/17) Yep, I'll find it when I get it apart. I'm
do it.
You need to do a leak down test to figure out if it's the seals.
