Christmas present
I needed these twice this year. Once when replacing hydraulic hoses on a skid steer and again when replacing brake lines on a ABS. I couldn't find any locally so I just struggled. I found these at Menards for $19.99 each, metric and SAE. I'll be ready next time.
I've probably had mine for 20 years and used them less than half a dozen times... but in situations where NOTHING else would work... worth every penny when you need them !
j
Use a extension and a impact wrench It will supersize you what you can rattle lose with them... I buy the cheap ones like that and grind them for open end use, I do not trust that cheap chit on a flare nut I have enoufh problems as it is...
