Ted in NE-OH
I have a couple of maintainers that seem to have too large of a threshold . It will allow battery to get too low of a charge before it will turn on. If a battery loses a few tenths of a volt (6 volt battery) that is a lot of charge. The later ones I have bought don't seem to do that. A few tenths for a 12 volt battery is not that big of a deal.
I have also bought some 6V/12V battery maintainers that when you plug it in you need to tell it whether you want 6 or 12 volts. The problem with that if the power goes out for a couple of seconds, the charger stops charging until you reselect the voltage desired. Unless you catch it, you may go a long time without any protection.
My 2 cents
My 2 cents
