Machine Shop Mathmatics
Ted in NE-OH
I have a right triangle, the base side is 1.13 in., The opposite side is .111 in. What is the acute angle. This is how I am figuring the angle (taper) for a steering wheel for an AC B tractor as I need to make a new steering wheel shaft.
Although I get along decently with math and geometry I have always struggled with that type of problem in the machine shop. I find it easier when duplicating a non critical taper such as a steering wheel shaft to chuck the old part and mount an indicator on the cross slide. Then adjust the taper attachment until the indicator says I am spot on. When making a part from print that has tight tolerances? I call the family math wiz,,,
If you can figure out the Trig { it is not that hard ]. You can make all kinds of parts. Kinsler Fuel Injection used to give out a card called "pocket Trig" . That little card helped me with a lot of math.
