Homemade Tool of the day
For several days I've been looking for an Alan wrench tool to reach four screws 6" deep in the bottom of an electric pressure washer. Everything I had was either too short or the shaft was too large to fit in the narrow shaft to get deep enough to reach the screws.
So today I made the perfect tool.
Everyone has the little hex and star adapters in a kit some where in their tool box. I could not tell the size of the head of the screw so I began cutting a slot in the top of the hex adapters. The third adapter or the 3/32 hex tool fit just fine.
I took a screwdriver with a 6" blade and hot glued it to the slot. I only needed it to unscrew the bottom of the pressure washer and re-screw the screws back in.
It worked!
<image src="http://forums.yesterdaystractors.com/photos/mvphoto6334.jpg"/>
In my Air Force days I remember taking a wrench to the metal welding shop to have it altered to facilitate an easier removal of an aircraft part. On removing an air duct in the wing of a F4 Phantom fighter/bomber I used a 1/4 ratchet with 4 extensions and a swivel. Had to put gum on the pinky to press into the nut to get the bolt to attach. A lot of times you had three other birds waiting on you for their four jet scheduled mission.
When I bought the metalworking shop where I retired, there was a set of long (appox 12 inch) long hex wrenches in fractional sizes and a drive handle with the correct size hole to serve as a handle. slowly they got lost.
I had a Wis V4 with stuck valves. I could stick a quarter inch allen wrench in the plug hole, rotate it over the valve and with a tap the valve would pop down. It had been soaking all winter. After a couple hours of tapping I made an external spring to push the wrench down as I spun the crank. Had all 4 exhaust valves working in about 20 minutes. On the first one I had to use an air hammer to push it down the first time. Intakes weren"t sticking.
I got sent to an office building to change out a lobby heater fan motor. That was required to get the squirrel cages off the old one . I went to Granger and bought a set of long T-handle Allen wrenches. Probably the only job I used them on.
Same setup on a lot of RV furnaces. I used mine a lot back then, still do occasionally although you couldn't pay me to work on an RV anymore.
