kcm.MN
- Location
- NW Minnesota
Many years back, I happened to buy a can of PB Chain Lube spray lubricant. This stuff worked SO well that I would use it when needed, but always kept it on hand. You spray it and it stick and stays in place. Maybe there's a better brand out there, but I haven't found it yet.
Anyway, had forgotten what brand it was - only that it came in a gold can. Haven't seen in in ANY of the stores up here in ages. Finally did an image search for chain lubes and found the brand again, so now can order some. However, I have to wonder why it's not more readily available?? Are there much better brands out now?
Here's the stuff I'm speaking of:
https://www.summitracing.com/parts/jbp-hdcl19
Would like to hear what you folks use when you need a lube that stays where you put it and won't sling off.
