Fluorescent light fixtures
showcrop
I am converting fluorescent light fixtures at church to LEDs with ballast bypass bulbs. So I need to replace the lenses as necessary. I am not having any luck far with my searches or with taking one to HD. I can't find a brand marked on them so I am hoping that one of the pros here has a source, where you order them by shape and size.
Are they troffer fixtures? HD should have them.
If wrap around, none are standard, probably cost more to replace the cover than buy new fixtures.
(quoted from post at 15:47:44 11/06/17) Are they troffer fixtures? HD should have them.
No, they are surface mounts. But they don't wrap around they are just the sides and the bottom.
Try Lumins For Less. I don't know a whole lot about them but they are in the same building I work at on Marlboro St. in Keene.
(quoted from post at 03:56:46 11/07/17) Try Lumins For Less. I don't know a whole lot about them but they are in the same building I work at on Marlboro St. in Keene.
Thanks Flembo, but I googled them, and they specialize in LED lights. These are 30 year old fluorescents that I am converting.
