My wife 2011 Chevy Malibu with 37K is having problems.
I was driving it the other day on the highway and noticed it shifted down going up every hill, it is lacking torque.
It threw a P172 and P175 code which means running too rich, but does not smell.
I hooked tool up to it today.
Coolant temp seems OK
Outside temp seems OK
Intake manifold temp seems OK
Baro sensor seems OK
MAP sensor seems OK
MAF runs 1 lb/min at idle and 4 lb/min on highway which seems OK.
TPS reads 24% at idle and is linear up to 90% when fully depressed.
The load % seems to be running real high, it seems to run at 40% load when in gear and 70% on highway, step down and it quickly goes to 100% load.
What else should I look for?
MAP sensor seems OK
