My water pump to the pressure tank is just cycling on and off if the water is used. So the bladder is ruptred or waterlogged.
I drained it and filled the air bladder to the 28# it said on the tank. Lost air a couple times but I kept filling to drain the water in tank out.
Now it's empty. I filled again with air to the 28 psi and now it's holding???? Put the pump back on and it's running as expected. Perhaps the shrader valve was leaking??? Any way I will keep checking.
But if it continues to slowly leak down I have a small pressure tank, 15ga that I could plumb in series between the pump and existing tank. Will the big tank give me extra reserve water and a longer draw down or will the system be limited by the size of the bladder in the small tank?
Any thoughts would be appreciated. Grant
