woodbutcher
I plugged in my Northstar electric power washer to wash my riding mower before I stored it. The 2 hp. motor would click and try to turn over, but never make a full revolution. When it tried to start, the lights in the storage building became extra bright, and then blew out. I had just had the motor off for a start switch problem, so I took it back to the shop. They checked it out and found nothing wrong. They said it could be caused by low-voltage. So, I got out my Handy-Andy multi-meter and did some checking. I took a reading on an outlet in the house, and it showed 120 volts. The house has its own meter. Then I went to my shop where the service drop comes down to a panel with its own ground rod. The outlets in the shop read 120 volts. UF cable runs underground to my tractor shed to feed a subpanel that has its own ground rod. Outlets in the tractor shed showed 134.5 volts. From this subpanel, triplex is run overhead 150 ft. to a subpanel in a storage building where there is no ground rod. Outlets in the storage building show 134.5 volts. I've used the power washer on outlets in the tractor shed and the storage building in the past without any problem. What could be causing these high readings now?
Butch
Butch
