Went to use my pressure washer that's powered by a Honda engine. While it was running it made a weird noise and stopped. There was no
compression after that. I looked for oil running on the ground and didn't see any. Didn't see any holes in the block either. I pulled
the valve cover off. Found the intake valve dropped in on top of the piston. The piston pushed it back up thru a new hole in the head.
