guido
Hello,
I replaced a pump assy. on a Pressure washer, and it came complete, with all the fittings. So I had the water inlet and the un loader valve from the old pump. I used the inlet water fitting to put a water clean out on my mower. I used a large washer and a rubber gasket...no leaks at the top. New one at the big box store is plastic and cost about $14. This was is brass and it was free, Guido.
