G6 at Snook, TX
I have three engine driven welders, but I only need two. The Miller Trailblazer I just purchased will stay, obviously, but I have a Lincoln Ranger 250 with about 250 hours on it and a Lincoln Weldanpower 225 from the mid - 1980s with an undetermined amount of hours.
I am leaning towards selling the Ranger due to value and the fact that I don't always need two welders at work all the time. The second welder would be used to build fence, but it's duty is light overall. With that, and sentimental reasons, I am leaning towards keeping the Weldanpower. What I need to know from you is this: the weldanpower has had an easy life, but somewhat neglected, and now runs great, welds good. That said, when it is used, it will run about 6hours in a day, but actually weld pipe fence braces about two hours out of the six it would run. Lots of idling, and some grinding cutting.
Knowing what you know about the Weldanpower (with the Briggs motor) how much faith should I put in it since it is a 30 year old machine? Are electronic parts readily available? Basically, I know the Ranger is newer and parts easily gotten, but it has more resale value. (Looks to be about $3500 around here as a starting point.)
If you were in my shoes, would you keep the Weldanpower or the Ranger, and why?
