(quoted from post at 00:57:42 08/18/17) My chainsaw has gotten very hard to pull the rope. It runs good after I get it started. I;ve read somewhere to put water? in the
cylinder overnight because the rings are cerboned up? Any help out there...EGBinOR
(quoted from post at 08:13:49 08/18/17) No it wouldn't go straight to crankcase because you would spray a light mist through air intake with hot engine and let it run for a while
after doing it.You might want to do it with screen removed from muffler.
(quoted from post at 17:22:48 08/18/17) Hello EGBinOR,
If A two cycle engine gets flooded BADLY, oil can separate from the gas mix, accumulate in the crankcase
and creates an hydrostatc lock. Try blowing the crankcase out with air. Take off the muffler or the carb to get access. Turn the engine to get under the piston and blow the crankcase out. Low pressure, 20 to 30 pounds is all you need. Also take the spark plug out and do the same. If oil is in there it is what makes the engine feel like it is almost locked up. Try it, it may just do the trick!
Guido
