PeaRidge180
New User
I need a set of hub bearings and wheel bearings for a Farmall M with a Norden front axle. The serial number for the front axle assembly is 216_ , but I can't see anything after 216.
We have taken the hub bearing and wheel bearings off the tractor and can't find numbers on them. Is it possible to measure the width of the axle and thickness of the bearings and then order the bearing? What are your suggestions?
Thanks.
Thanks.
