I have 2 but I will not say brand name as it has no reason to be mentioned except they are both the same brand. One is a 110 volt corded rated at 240 ft lbs on box when bought and second is a 18 volt cordless that was rated on box at 360 ft lbs of torque. If ft lbs rating is correct why will the one with 2/3 the amount of the other easily take off tight rusted nuts that the one with higher rating will not touch? The corded model weighs quite a bit more than the battery one. And yes I did try different fully charged batteries. The battery one is just easier to handle with the less weight and no cord to mess with while tearing apart the hay rake to rebuild. And I can take it with me in the truck. I have has air powered previously but do not have the air avaible to run one where I need it but I can lay put an extension cord for where I am at.
