Speedi Sleeve
Bret4207
Anyone have a recommendation on a good place to order Speedi Sleeves from? Got to sleeve a shaft on an 488 haybine.
Link is to the SKF site catalog listing. Find the part number you need and use it to find an online supplier. Lots of them on Ebay sometimes real cheap. Hint, be sure you search both "speedy" and "speedi" if you search Ebay due to lots of misspellings.
SKF Speedi Sleeves
Found two for the brake cross shaft for my Ford on eBay for almost nothing. measure the shaft and get the size that fits.
We used one on a final drive on our combine that was leaking last year. It worked great. I found out the size I needed and it was actually ended up being a metric size that crossed over to the american size we needed. The one I needed was available on ebay but it was sold mostly in the UK. I got the part numnber and had dad go to Motion Industries in Lansing Mi and they ordered it as easy as pie. The thing worked great and we now have a combine with no leaky final drive! I think it cost about $70 dollars and dad made a jig to press it over the shaft that worked flawlessly in about two minutes. They have a flange on them that you use to press them on. You can leave the flange on or take it off if you want to. We left it on because it wasn't bothering anything. Good luck.
