Steve@Advance
There are many different types of orings, different materials, hardness, etc. Not sure what flat rings are? Back up rings? Possibly quad rings?
If this is a hydraulic shop, they should be able to match the piston design with the proper seal.
But for the seals to have only lasted 2-3 years, came out hard and crumbling, and you say it is getting hot, something doesn't sound right. A log spliter should not run that hot.
Is the pump unloading between cycles?
